R&DMACHINIST
Thread starter- Joined
- Jun 27, 2011
- 71
Here's any easy one for ya! On my 54 CD-11 only the top spark plug has fire, the bottom one does not.. The plug wires appear to be fine just looking at them.. What direction should I head next?
For my TD-20 I pour gas in the tank and it almost immediately started dripping gas from the carb or pump? Not really sure but when I turned the fuel valve on it went from a drip to a steady stream,and when I pulled the rope a couple times it started squirting fuel out the top of either the carb or fuel pump.Question is which is it that has the problem the pump or the carb? And also can it be fixed or does it need replaced?
Thanks!
Thanks!
