I was using a mix ration of 24 to 1 on a 67 evinrude 5 hp angler, and was having choke problems. Then I put a new fuel line on and the problems with the choke went away, so I changed the ratio to the recommended 50 to 1 and now about 80% of the time when I start it up and run it for two minutes I completely lose power and the motor cuts off. But after I restart it it ussually runs fine. Am I running too much gas through the motor now? Is it the new fuel mix that is causing the problem? I was not having this problem with the old fuel line and mix ratio.
