Re: changing 8" tires to 13" tires.
the reason you need to run trailer tires at higher PSI than seems right is so they won't roll off the rim on a turn. there's a lot of outward centrifugal force going on back there, more than on the car.
Not really; have you ever looked at the front tires on a car in a hard turn there is much more force there than a trailer has in even the hardest turn at speed.
My Load Star 480 X 12" tires on my 07 Load Rite trailer are written this way; load range B 785 lbs at 60 psi. No indication of must be run at that pressure only that the rating is at 60 psi.
The 8" tires on my 02 Chinese utility trailer are written Load range B 585lbs at 60PSI.
No indication they must be run at 60 psi only the rating is at 60 psi.
I think that implies if you are running lets say half that weight somewhat less pressure may be indicated obviously run enough pressure so as not to stress the tires.
I think changing springs in his case is out of the question.
My Load Rite is rated for 1500 lbs My 18 ft utility is about 800 lbs all up.
In this case I will be running 60 psi. and I don't think i need to be searching for different springs.
Load range for his 13" tires must be about 900 or a 1000 lbs at 60 psi
I think with his about 500lb load a little less pressure may be in order enough to ease the ride yet not stress the tires.
