Re: changing 8" tires to 13" tires.
the OP still has his motor and trailer frame bottoming out (look at the ground clearance and not just the boat height) so while lifting the bunks is a good idea, flipping the axle is going to be a better step in getting him the safe ground clearance he needs. if he needs more clearance after that, then he should raise the bunks. either way the boat will be higher but my way the trailer frame wont still be dragging the ground on curbs and steep hills.
you have your opinion and I have mine. the OP has heard both and will do what he thinks is best for his own peace of mind.
No such thing as "normal" position... they are installed both over AND under on different trailers.... You can't possibly know that it isn't in the factory original position...
I have yet to see one single light weight 1500lb or less boat trailer sold with factory axles mounted above the springs
MOST trailer axles have camber built into them and installing them upside down can lead to tire wear problems... to correctly "flip" a trailer axle requires that spring perches be mounted on the top or bottom to allow the axle to mount in it's original attitude.
again you ONLY think in terms of what you are used to which is large big heavy boats with large heavy trailers so your point of reference and viewpoint reflects only that experience. while its true that MOST large heavy trailer axles have camber built into them, its also true that most light weight trailers do not and they do indeed have perfectly straight non cambered flat axles. cambered axles only show up when you start to get into the heavier class single axle trailers. when you shop for new straight axles they have them with or without camber depending on the axles weight class and the straight axles are designed to give you the choice to be mounted over or under the springs. I am surprised you didn't know all this.
I just counted... of the 9 trailers here on the property 2 have axles under the springs and 7 have axles over the springs. All are believed to be in factory original positions.
are they boat trailers or utility trailers? and what are the brand and weight class of those two trailers that have factory axles over the springs?
