MikeSchinlaub
Ensign
- Joined
- Jan 14, 2025
- 977
Leave the edges for now. It will help get the stringers to the correct height.I will actually remove the remnants of the original floor along the sides.
What was your spans for the floor? Would you think 22+ inche span would be ok for 1/2 inch floor?Same, I used 3/4" Auraco for stringers and transom, and 1/2" Auraco for the floors
Yes. My center span (inside the ski locker, so no foam underneath) is 26" at the back tapering to 18" at the front.What was your spans for the floor? Would you think 22+ inche span would be ok for 1/2 inch floor?
The balsa made me think of Nida-Core H8PP 13mm. This is reasonably affordable, or PET Foam 5lb 3/4” by DIAB. Would I be able to use the Nida-Core for my stringers? And the PET Foam sandwiched between glass for the floor? Looking at the price, it is cheaper than Marine ply or Baltic Birch.I have over 28" span with 1/2" balsa for the deck sole in the Rogue. There is almost 1/8" of fiberglass on both bottom and top
However there is a rib every 24"
