Garnett-Devon
- Joined
- Oct 23, 2016
- 11
Hi - the gears in my Mercury are in a pretty poor state. I bought an old gearbox with a broken Skeg to do a transplant!
Getting the shaft and pinion out was a pain. After removing the water pump I ended up having to chisel out the plastic water seal until I reached the bearing lock but. I don't want to be as brutal when I remove the pinion and shaft on the gearbox that I am keeping! Is there a way to do it or do I just order new seals and assume that I will be forcing entry again?
Any advice appreciated
Thanks
Garnett
Thanks
Garnett
