check engine is coming on and off, so is the buzzer
randy87
My check engine light started coming on the 2nd time in the water this year. I know its not the water pump, and i premix the oil, so I dont think its them. My voltage meter show postive when running. Could it be a bad spark plug? since the check engine comes on sometimes and goes off sometimes? or is there a fuel problem. i am lost on this thing! running great when i put it up last year. the engine is a 1997 johnson venom 200:
Re: check engine is coming on and off, so is the buzzer
The Check Engine alarm is a vacuum in the fuel line, caused by clogged filters, stuck antisiphon valve or some other restriction. You need to check the filters, mainstrainer and antisiphon valves for restrictions.
randy87
Thanks Chris, I will check my filters. Ive been pulling my hair out over this thing. Thanks again for your reply. You the man!!!!!!!
