oops!
- Joined
- Oct 18, 2007
- 12,932
Re: Chemical to remove oxidiation from gel coat.
This is correct.....i do this for a living....
the only caveat i have is that a good 3m rubbing compound will take care of most oxidation. only the worst will require re surfacing.
the magic eraser thing......is just bleach and wont harm your gelcoat (gelcoat is really a fantastic product) but it also is a short term solution.
First off oxidation and dirt/grime/hard water deposits/stains are two different things and require different approach in removal. Chemical wash, acid wash or what ever other chemical agent will work on the latter but not on oxidation. The only way to properly fix oxidation it to remove it by sanding and buffing. If the oxidation is minor some rubbing compounds will take it out as they remove very thin layer of gel coat. Some have used Vaseline to mask the oxidized look but that is a short term remedy with limited results. As said before, the only true way to remove it is with ample dose of elbow grease. Good luck.
