economate2
Thread starter- Joined
- Jul 29, 2011
- 36
It's a 6 horse Chrysler outboard Model: 64H9E.
Took apart the carburetor, cleaned it all out.
Cleaned the fuel hoses.
I checked the spark plugs on another motor that uses the same ones and they both work.
I tried pulling the starter with the spark plugs out, connected to the cables, next to the metal housing, but didn't see any sparks. Maybe I'm not doing it right though.
The spark plugs are wet when I take them out after trying to start it.
The motor just won't start. I admit I'm trying it with old gas, but I figured I should at least get it to fire. Give me some sign of life.
The bulb on the fuel hose pumps up and becomes firm. I tried it on Start, and Fast, with the choke open and closed. Hasn't even fired.
Just when I got the motor, the flywheel was stuck and I had to use a socket wrench on the top nut to force the flywheel to start moving. Now it moves pretty well though.
I appreciate the help in advance.
