Circuit Breaker, where does it go after wired?
wilson!
I know where the CB goes in the wiring diagram, I mean, after everything is wired where does it get stored?
I have a 12' inflatable boat running a Minn Kota 30, 12V battery.
Does the CB just dangle freely in the boat? The battery is in a battery box so does the breaker just bounce around in the box?
This is a picture of the CB I have (not exact one):
http://www.delcity.net/store/Manual-Reset-Circuit-Breakers/p_198672.a_1
Thanks :confused:
wire2
Re: Circuit Breaker, where does it go after wired?
I expect it's the "push button" style that fits in a ?" hole with a locknut? Drill a hole in the battery box and install it. To let it "dangle on the wires" is asking for trouble.
Ok, I just looked at your pic, it's not the push button style.
Same answer, bolt it to the inside of the battery box, where there's space, not touching the battery.
wilson!
spoken like a true geniuos. did i spell that right? oh well, thats why im the one asking.:D THANKS
RicMic
I made little plastic hangers for mine, so they hang right below the lid of the battery box, you could do the same with a strip of aluminum. I have the kind with the manual "test" button, which allows me to use them as disconnect switches, so I need easy access.
