Cleaning camper canvass windows
agallant80
I tried google without much luck. What do I use to clean the plastic windows in my camper canvass?
Re: Cleaning camper canvass windows
If the windows are just dirty then use only a mild soap & water & a sponge. Nothing abrasive as you'll see the scratches whenever the sun shines on them :(
Depending on what they are dirty from.
Meguires makes some really great products for cleaning plastic windows. Non lemon pledge also works after the main dirt is removed with soap and water.
However if they are yellow and discolored, then they simply need to be replaced. Local canvas shops will do that for not a lot of $
rbh
There is a polish with a light abrasive that removes "most" yellowing/milky and scratches, I have a tube somewhere, just cannot remember the name.
agallant80
The windows are new they just have sea solt dried on them. I would like to clean them before the boat goes up for the season im just not sure if Windex is the best option.
rbh
Don't use windex, the windows could go milky.
Just mild soap and water then rinse.
smokeonthewater
soap and water
for aged windows McGuire's plast-x
Slip Away
For routine cleaning and upkeep, use Plexus. Soap and water in a pinch is okay.
