starsnstripers
Thread starter- Joined
- Nov 30, 2007
- 1,330
1988 4.3 MC Clean low hour boat/engine only seen fresh water. My question is if anyone has done this without cooling complications? I have a 5.7 heat exchanger and would like to change this raw water 4.3 to a closed system before i dump it in the salt water. Block off the risers, change therm housing, do the hose plumbing, and the main question- use the Alpha outdrive water pump to feed the exchanger and risers instead of installing a seperate raw water pump? Can it handle the job? My thought was where it's a 5.7 cooler cooling a V-6 the drive pump could do the job?
