Georgesalmon
- Joined
- Apr 14, 2012
- 1,793
OK, some background: I restored a boat last winter and of course did a major rewiring. Everything new and protected with breakers.
I have found only one problem; when I try and trim the engine at speed I blow a 20amp breaker, works fine on the trailer or idling in the water. Did some research and found the 20amp is not big enough I should have a 40amp breaker. Over the years I have acquired a box of 12vdc breakers from 3amp to 20amp nothing bigger. Here comes the dumb question:
Is there any way to use two breakers in either series or parallel to get a higher rating? I'll buy a 40amp breaker if I have to but I have looked and can't find one that matches all my other ones. I know it sounds silly but it would be really nice to have everything match. I suspect that I can't make this work but it would be really nice if I could.
The pictures show a couple of my power panels that have yet to be painted.
