roscoe
- Joined
- Oct 30, 2002
- 21,939
Ok, just picked up a boat, has the 1973 Merc 65, no power tilt.
This power plant is the bare minimum I can imagine using.
But, I have a 2002 Merc 50 elpto sitting in the garage, less than 40 hours on it.
Question is, how far apart are the actual motors hp wise?
I really would like to put a larger motor on the boat, but would use the 50 temporarily till I could find a larger one.
The problem with a larger motor, is that all I seem to run into are the OMC v-4's.
I have just never ben a fan of them. And they are wide, posing a space issue on my transom. I can't find a larger Merc or Yamaha for anything.
So do you think the 50 is even worth putting on the boat?
Boat is a 1973 18' Starcraft SS, hull weight about 880#, just under 2000# under normal running conditions with main and kicker motors, fuel, gear, and passengers.
Opinions?
Opinions?
