compression after rebuild?
UNjim
What kind of compression would you be looking for after rebuilding a '56 Johnson 30HP. What did they have originally? THANK YOU!!
JB
Re: compression after rebuild?
Both cylinders within 10%. That cannot happen unless both are relatively healthy.
DO NOT get psi paranoia. There never was a spec and as long as guages, technique and conditions are inconsistent there never will be.
Typical readings could be anywhere from 50-60psi to 140-150psi.
