chaparral285
- Joined
- Sep 8, 2007
- 6
Can someone tell me how much cylinder compression I should have in a 2000 5.7 Volvo GSI?
Thanks,
Harry
Thanks,
Harry
Welcome to iboats......Can someone tell me how much cylinder compression I should hace in a 2000 5.7 Volvo GSI?
Thanks,
Harry
Chapperal- Your readings are to high. When your getting up over 150-160PSI your getting into what i call "race car" compression ratio's... at 170PSI your ratio is 12:1... way to high for a boat motor...
Imported rob~ pulling all the plugs to do a compression ratio is dangerous... especially in a carbed motor.
First of all... pulling all the plugs will more or less double your cranking rpm.
So... lets say if you pulled the plugs and your cranking rpm is now 1200... (double 600... as the average cranking rpm is 5-600). your carb is pulling all the fuel it normaly would be pulling at 1200 rpm... and with all the plugs out the fuel vapor would be going everywhere....
its a sure way to have a flash fire.... and a 1 way ticket (my term of the day) to the ER. A bilge is a mighty small area... especially when it's full of fuel vapor.
Do you know why mercury says to pull the plugs there bucko?????
A little full of yourself there Jason?????You will soon learn not to contradict me......
