Gents, Anyone tell me what is acceptable compression on a 96 Johnson 2 stroke?? Thanks, Dave
daveydoodle Petty Officer 2nd Class Thread starter Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #1 Gents, Anyone tell me what is acceptable compression on a 96 Johnson 2 stroke?? Thanks, Dave
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jun 13, 2012 #2 Re: Compression readings 96 2 stroke what, it will vary depending on horse power. What readings are you getting now?
daveydoodle Petty Officer 2nd Class Thread starter Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #3 Re: Compression readings Above is a 15 hp, sorry..Dave
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jun 13, 2012 #4 Re: Compression readings If you are rope starting it, I would think anywhere around 85-95 would be good, but the cylinders should be within 10% of each other. If it has not be run in a while, it might be a little lower, but will come up some after you run it.
daveydoodle Petty Officer 2nd Class Thread starter Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #5 Re: Compression readings Thanks Daviet much appreciated.
