Gents, Anyone tell me what is acceptable compression on a 96 Johnson 2 stroke?? Thanks, Dave
daveydoodle Petty Officer 2nd Class Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #1 Gents, Anyone tell me what is acceptable compression on a 96 Johnson 2 stroke?? Thanks, Dave
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jun 13, 2012 #2 Re: Compression readings 96 2 stroke what, it will vary depending on horse power. What readings are you getting now?
daveydoodle Petty Officer 2nd Class Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #3 Re: Compression readings Above is a 15 hp, sorry..Dave
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jun 13, 2012 #4 Re: Compression readings If you are rope starting it, I would think anywhere around 85-95 would be good, but the cylinders should be within 10% of each other. If it has not be run in a while, it might be a little lower, but will come up some after you run it.
daveydoodle Petty Officer 2nd Class Joined Jun 15, 2011 Messages 160 Jun 13, 2012 #5 Re: Compression readings Thanks Daviet much appreciated.
