compression?
210ccr
how many pound's of compression is normal for 5.7 volvo penta?
rbh
Re: compression?
I am going to wing this one, but I would say a new engine just broke in bellow 10-1 compression would be 190-210 psi.
normal used engine 170-190 psi
just a guess
rob
Don S
Re: compression?
You sure have high expectations without even knowing a year of his motor.
rs2k
Re: compression?
I know you can't really go by this, but 10:1 x 14.7 = 147 PSI.
Without reading the manual I would imagine anything around 150 with a 10 - 15% highest difference would be good.
If the highest read 155 then the lowest should not be lower than about 130.
Make sure you check the manual though.
210ccr
Re: compression?
i'm getting around 165 on all cylinder's, thank's for the info guy's!
bruceb58
Re: compression?
You are right...you can't. You have to take into account the specific heat ratio of the air.
