Computer Packing Foam for Foam Replacement?
nhangler
Not polystyrene, rather closer to a pool noodle but heavier. Comes with dell PCs and servers.
I tested a chunk of this stuff submerged in water for a day. Weighed it on a scale before and after. Absorbed no water. Have not tested against gas / oil hull smudge yet but I can get plenty of this stuff and have enough to do my 17' aluminum boat.
Anyone else tried this?
Anyone put theirs in a bag or protect the foam from the chemicals that could be floating around the inside of your hull?
ezmobee
Re: Computer Packing Foam for Foam Replacement?
I think you're correct that it's polyethylene foam, same as noodles. I can't see why not!
Woodonglass
If you can get a LOT of it, then yep, it is the SAME stuff
Cadwelder
Wow another floation material added to the mix.....pool noodles, ping pong balls, blue and pink sheets, pour in 2 part foam and now computer packaging....just keep getting better.
ezmobee
The noodlers do not appreciate your snarkiness. This insubordination has been noted.
MichaelP
Noodlers are the folks that catch big cat fish with bare hands. Their crazy too! :facepalm::D:eek:
I would just be sure not to use the environmentally friendly peanuts. Those are a 1 shot deal. :D
CBGale2
Don't forget laundry bottles. :D
pete s
I have an endless supply of bubble wrap what are everyone's thoughts on that. I am planning on using it when the time comes. (hopefully in 2 weeks or so)
Cadwelder
I really hope that's a joke....
jasoutside said:
That's about the dumbest thing I ever heard. Almost as dumb as that pour in foam garbage. But not quite.
What's wrong with the two part foam?
jasoutside
Frisco's Glasser...
Water under the foam everywhere
Just one of many my friend. Pour in foam = no drainage.
Metal boats aren't as bad but still cause corrosion when the water gets trapped by the pour in.
Noodles, foam board, pong balls, soap jugs and all sorts of other interesting displacement items provide drainage and foltation:)
pete s
No it is not a joke. Why wouldnt it work for flotation, basically the same principal as foam just on a larger scale, tons of small air pockets.
Ciera2450
I have 50 pool noodles under the deck in my little runabout....
If she splits in half or something...i'll have plenty of noodles to grab ahold of! lol
Cadwelder
Go for it man.....
jasoutside
I'd be concerned that water would sit in between the layers of bubble wrap and eventually mold would set in. Lot's of options out there that would be better than bubble wrap.
Kudos for thinking out of the box though!
jasoutside
Hey Dave (cadwelder), yur pm box is full;):D
nhangler
Yes, we buy lots of hardware that comes with this kind of packing foam. I started grabbing it for my flotation foam for the boat. I should have plenty. Just hate seeing it get thrown away only to go to a landfill.
See, going green is more than just the effects of me hitting my lawn 4-5 times a year with the scotts nitrogen enriched fertilizer! :D
Regarding the bubble wrap idea, I would suggest against that. I would think that it would degrade a lot quicker and be ineffective. Remember that there is more than just water sloshing around inside of your hull.
Yacht Dr.
Your forgetting that some of use use 3/4"-1" drilled out pvc along our stringers before we pour foam in there for drainage ;) .
PS. look like your giving the birdy in that pic lol :) .
Tons of water to be entrapped .. good idea short term..but man would I not want to take the shrink wrap off that boat in the spring : ) .
On a side note about noodles.. its would be kinda ez for the coasties to locate you when you have noodles floating all over the place ( Im not kidding..good spot for flyovers ) .. Id would float on the beer cooler..but hey.
I Wholeheartedly Agree with this !! Thinking out of the box is what makes this forum Great .. I learn a lot from these guys with something "new" .. just not this one ( cant win them all ; ) ).
I hope there is No water sloshing around in any boat LOL !! .. if there is then your foam is the least of your problems. Not saying anything personal against your post there angler..I think we know what you mean :) .
Here is the REAL DEAL on foam and/or floatation methods from a professional point of view..
Some boats require foam for "floatation".
Some boats require foam for "integrity" .
Some boats have foam in places where it would not require it ( waste of time and effort ).
Some boats have foam in places just to fill "dead" areas that could be used in smuggling contraband ( trust me I have seen it )
For non structural boats I see no reason not to use the "pool noodles" if properly sealed/welded at the ends for flotation in NON-Structural foam builds ! ( just pay me 90 bucks an hour and It could cost you more then the boat is worth for a noodle install )
Plastic bottles are IMHO the best because of there shape ( mostly rounded ) and cant really trap water between them therefore draining to the bilge and evacuated VIA pump or plug ( never seen a plastic bottle mildew either ).
Any other kinda of material that will not allow water to completely drain into the bilge will eventually mold and mildew. Leaving those spores to come into the cabin area ( if you have one ) or cushions etc. You cant just start cramming PC foam or wrappings into your boat without long term side affects.
Structural foam build boats needs that 2 part foam reinstalled just like factory. You can add some modded drilled out pvc to the lowest point of the compartment to aid in the drainage of water if you like.
Foam is one of two things .. Structural ( needs to be re-foamed ) or Floatation.
Noodles or bottles might work for you..but not the next guy. So make SURE you know What YOUR boat needs before Foaming or using an alternate floatation system.
YD.
Tahorover
Mold will only grow were it has a food source.
Yacht Dr.
Be nice if lakes or oceans were distilled water bodies..but no.. microbes are there with there food source.
YD.
