confused and frustrated
flydragonfly
i bought a 1991 regal boat 17 ft thats all the info my title gives me i tried contacting regal boats but get the run around .im trying to figure out what model my boat is and other spec. it has a 3.0 engine i want to rebuild but dont know any other details about engine if i understand correctly the id numbers are located on back of block where i cant see while in the boat it runs so i dont want to pull engine till i ha.ve everything needed to rebuild.heres somerthing someone sent me but whern i try to user as description for engine numbers it cant be found. i was sent this info cansomepne help intertpret this and or tell how to find out the boat specifics please 1991 170v hull number: rgmal559h091 short hull number: AL559 engine 1 : egm30l =d444649 drive 1=drn1.98a-d454103 someone says missing number
Earl Cordova
I'll bet Regal will be of no help on a 30 year old boat.
Chaparral wouldn't help me with mine when it was 1 year old,
they told me to contact the dealer.
poconojoe
Use your cellphone camera to reach around the engine to take pictures. Hopefully you'll find the casting number that way.
Why are you thinking of rebuilding the engine? Does it have a problem?
GA_Boater
Look at this for the serial number location. As poconojoe sai, stick you cellphone there and snap pics.
achris
More fish than mountain goat
That's a 1990 3.0L engine with a 1.98:1 drive.
That's an 86KW (@4200-4600rpm) engine. And the drive is known as an 'Alpha One' (sometimes incorrectly referred to as a 'gen I').
The serial numbers you quoted aren't quite right. Here they are corrected.
Drive - 0D454103
Engine - 0D444649
'Boat' and 'engine' are 2 separate entities. Unlike car makers, boat builders don't build engines, they buy them from Mercruiser (or Volvo or OMC, or Honda, etc) and installed them in their boats.
When you are looking for parts and information, those serial numbers are the thing everyone will ask for. When you post questions on this forum, we ask you put those numbers, and the year of the engine/drive (not the boat) at the top of the opening post of any thread. And because the 3 litre engines of that era could have any one of 3 different ingition systems, we do ask that you specify that too. They will be Points, EST (electronic distributor) or DDIS (like a coil pack with 4 spark plug leads coming out), see below.
Chris.......
