Contour maps?
matt167
I have an older Lowrance HDI 7 and a Humminbird Helix 5 gps. Both I do not know the exact models. The Humminbird is fairly new but not latest model. I tried to figure this out but only got more confused. I want to get contour maps for Cayuga lake and Onieda lake. I can’t figure out what I need to do. Can I simply buy a chip from Bass pro or something? Onieda is new to me and I know that the bottom comes up quick.
dingbat
Some units come with maps, some don’t.
If the unit(s) didn’t come with maps you need to buy the appropriate chip.
I believe Humminbird supports c-map. The lowrance could be c-map or Navionics
arks
Matt- while you’re figuring out the electronics, you can look at bottom contours on fisherman.com. Hers a closeup I just pulled around Oneida Marina:
DeepCMark58A
Yes go to bass pro or online and order the chip for the hummingbird. You won't regret spending the $
airshot
My Low dance HD 7 is a 2013 model and previous owner bought a North America card and installed it ...it shows everything in north America from contours to roads. Only guessing that he bought it from Lowrance, I would call them first.
matt167
My lowrance I’m pretty sure is a similar vintage.. both have maps, but no contours. It shows the body of water and where I am, and I can track myself to a pin back to the launch ect… I normally use the Lowrance as it’s easier to see
FLATHEAD
Oneida has some humps and bumbs for sure. Most is marked. Sometimes the wind there can make the place absolutely miserable to fish.
matt167
Where is the best place to launch out of? South shore boat launch is closest to me, but didn’t impress me when I checked it out. Snug harbor I also checked out but it seems like they cater to race boats and high dollar boats.
FLATHEAD
When we fished there we stayed at places that had private ramps and offered docking. Three pine lodge is one. We also stayed at a place on the route 31 side several times with the same set up. Can’t remember the name but it was cheap and clean. I’m sure a lot has changed as far as lodging since we used to go 20+ years ago.
We fished all over the lake, I did well mid lake to sylvan beach.
Pmt133
I used a Navionics card in my 581 which allows for contour. When I had purchased that particular card you could load in whatever region you wanted from the PC and have the charts for it and you got updates to the chart data for a set number of years vs buying a region specific card. For what I do it's fine but I believe the better cards do offer more detail. I have noticed channel markers are no longer correct on it as over the years they've been hit and or moved/replaced. The contours are spot on for the most part.
airshot
On my unit, I can choose different pages and settings to view. The contour images only show on certain pages. It has taken me a couple years to figure out all the bells and whistles. If it shows the body of water you are on, then go thru the menu and settings and you might very well find those contours, along with other info.
FLATHEAD
The Garmin Navionics has a setting that’s called depth shading. Different colors for different depths. It’s very handy for fishing
matt167
I’ll have to play around with it. I didn’t think I saw a card in it but it could be. Would be nice if it’s there. The previous owner was a lake Erie walleye fisherman so the card for that should also have NY lakes on it as well I think
