Coolant coming out of sterndrive.
langford7
1984 Del Magic W/ 470 and Alpha 1 Gen 1 Sterndrive. When I put coolant in the engine it comes out of the sterndrive. So I change the exhaust riser gasket thinking it was leaking by there, no good. Then I opened up the heat exchanger and there was coolant on the tube side. So I then took it to a radiator shop to have it pressure tested and it's fine. The only other thing I CAN think of is the exhaust manifold.
Thanks,
Billy
Don S
Re: Coolant coming out of sterndrive.
Sure hope you had the proper gasket between the riser and manifold. If not, there's your answer.
Ayuh,... Duplicate Thread....
Don S
I deleted the other duplicate thread.
Ayuh,.... Imagine That,..... I picked the Wrong 1,........:D :rolleyes:
langford7
Yes I posted it twice I didnt see the other one and I thought it had been deleted. My apologies..... Yes it is the right gasket. It is the one were there is vein holes in it for the coolant.
Ayuh,... I Think that's the Wrong 1....
With the closed cooling,... You should have a Block-off Plate,+ gaskets....
I Think.....
Don S
Make sure you have the PROPER OEM gasket with the proper openings in it. Then install it the correct way.
I have seen people try to make gaskets for the exhaust on the 470's and not know which holes to have open.
langford7
Thank you everyone. That was exactly the problem.
julius750
Sounds like leaking manifold.
Edit: NO SELLING on forums.
