Diggerpine
- Joined
- Jun 8, 2009
- 15
I had the misfortune of dragging my lower unit through some gravel. The engine temp got up to 220 degrees for a few minutes after this happened and I got it to shore to check for any obstructions in the water intake ports of my lower unit. I also checked the prop and it was OK. The intake ports were clear and after getting under way, the engine temp dropped back down to 160degrees. (It was running about 140 degrees prior.) Could I have sucked up some debris into the water pump? Should I check the impeller for obstructions?
Thanks for any input!
Steven
Steven
