mancho
Thread starter- Joined
- Apr 14, 2011
- 121
I think I'm in the right forum, so don't kill me if this needs to be moved... it's not really a "repair" topic as much as a new boat owner and having general questions.
Ok, so I'm back on the water this weekend w family and a friend and we can't pull a 100lb boy OR an adult out of the water.
My mechanic (that changed my flywheel... this thread: http://forums.iboats.com/showthread.php?t=479506 ) said the 19 PROP was more desirable to get me out of the hole faster than the 21 that I had on it. So I swapped him mine for 50 bucks and this weekend didn't prove that it was any better.
However, I have NOT tried to pull anyone prior on skis only tubing. SO I don't know if the 21 was better... only pulled tubes on that prop.
This boat is rated at 280 HP. After I emptied the cylinders of water from the hydrolock, dried them out I put in NON gapped new plugs. but a .1 gap compared to the spec'd .03 gap, is that a big difference if the firing is "that tardy"?
The mechanic that changed the flywheel gear didn't do a compression test, he said it sounded great. However, the water load and actual lake testing is different than running on muffs in the shop of course.
This has the GM V8 vortech engine (5.7 Liters) ... this boat.. I would think a big enough engine for a 20 foot boat.
So it's either the engine isn't putting out 280 HP, or I'm significantly loosing it somewhere. We had just 2 adults and 2 100lb boys and 1 50lb girl. Not significant weight with 3 sets of skis in this size boat. No other big weight besides my 40lb tool box.
Help ! Any suggestions is great.
