Im Lon 2
- Joined
- Nov 29, 2013
- 123
Im in the process of purchasing a 2008 Tahoe Q6 190 HP. I went and looked at it yesterday, and had a few questions.
1st there are a few thin cracks in what looks to just be in the clear coat by both front cleats. Is this normal? What is the cause? I have checked out around the entire boat did not see this anywhere else.
2nd the sheg had a gash taken out of it, and he had it filed down by a shop to where it is smooth. Will this cause an issue on performance? Can I just get a sheg gaurd slip it over and everything be fine?
These were the only 2 things I see that could be an issue, that I have not dealt with in the past
Couple other things.
Need some good stuff to clean things up a little.
The driver, and passenger seat has yellowed just a tad from the yellow life jacket left on the back of the seats
More cleaning needed on the the bottom side of the Sundeck. Again what Is a good cleaning product?
What is the best way to fix the clasp under the front cushion/cooler? Looks like it got knocked loose and stripped the threads
Other than the top two, and a little cleaning the boat looks great.
Thanks in advance!
Lonnie
Thanks in advance!
Lonnie
