Crazy gas saving scheme, will it work?
Windykid
Re: Crazy gas saving scheme, will it work?
Yea my vehicle is now powered by water and my light saber. And gets 20000miles to the pint.
Some people just dont listen till they loose their money and blow up their car. Especialy when they are already getting 30 miles per gallon.;)
gonefishie
So it will separates the H2O into 2 Hydrogen molecules and one Oxygen molecule and then shoot it into the manifold together. Therefore, recombining the two gases so they will be bond together and become H2O again. Why are you splitting it in the first place?????????
JB
LMAO @ Jay.:D:D:p
i386
IIRC
Just putting the two elements into the same space doesn't make water. I'm not sure what's required to make them bond though. Throwing sodium and chlorine in a bucket doesn't give you salt either. Anyway, put a spark to hydrogen and oxygen, and you get water and energy.
QC
Do you guys remember the moth ball fuel saving thread I posted a year or so ago? A friend of mine plopped down $500 to be a distributor of the magic Gas Saver Pills? . . . What I learned in that one is that there is a placebo effect to doing anything. After installing a device, or dropping in the Magic Pills, the operator is more conscious of his/her driving habits, so they do in fact get better fuel mileage . . .
That is my fear for Sarge here. He is gonna come back with impressive results and all of the perpetual motion, energy in equals energy out, stuff is not going to convince him of anything except that we are a bunch of old farts who can't learn anything . . . Well I guess he'd have that right :eek: :D
TerryMSU
As an engineer, I can answer some of the questions.
1. Electrolysis does not produce any "toxic fumes"
2. Electrolysis requires two electrodes. If these are not platinum, they will quickly wear out.
3. Electrolysis does not use an "electrolyte". It uses pure water. note: the "pure" water must be distilled or you will kill your electrodes.
4. The alternator places a load on your motor directly related to the electrical load you draw from the alternator. It does not put out 13 amps regardless of load.
It is extremely doubtful that this will work.
Comment on item 3 above. It seems like maybe they added some sort of acid to the distilled water. I sure as &*^% do not want acid rusting the inside of my engine.
If this worked, the big three would have been doing it. They will do anything to meet the CAFE (Corporate Average Fuel Economy) requirements. Even a 1% improvement will save them millions in CAFE payments.
Terry
SuperNova
You might want to talk to somebody about how your little gizmo is going to affect all your emissions control components such as O2 sensors and catalytic converter.
Stan
Windykid
QC i'm with you on that one. But dont mothballs make higher octane, there for actually increase mileage slightly?
QC
Common misconception, Octane has nothing to do with energy content, only knock resistance . . . The Mothballs actually do have some energy content, and they do increase octane slightly as well. The energy content thing would theoretically increase tank mileage, but when a pill costs a coupla bucks, it does NOT improve economy or efficiency, you have just added a little more fuel . . . that is more expensive per BTU . . . BTUs in = some horsepower out (usually at a rate of around 30%), this is the thermodynamic stuff that Sarge thinks he's gonna beat ;)
Turin
IT would be so funny if you saved 0,5% fuel.
It would mean it works.
Im a beleaver :cool: I think itll work.
but the distilated water will cost probaby more than the fuel you save.
but it sounds like a fun projekt,
there is this guy in the tow where i live he runs his old mercedes 300 diesel on 80% sunflower oil.:D
it wiorks but its illegal:rolleyes:. (it smells to:cool:)
SgtMaj
Stan
Well that's why I was here asking about it... but so far I've mostly gotten assinine answers such as "it takes more energy to run the alternator." As if my vehicle didn't ALREADY run the alternator whever it's running and somehow magically teleported itself from one location to another. Others seem to think I'm trying to completely eliminate gas consumption as if it was some sort of free energy generator... apparantly they can't grasp the not at all new concept of reclamation (otherwise known as improving efficiency). These are of course the same people who thought the airplane on a treadmill wouldn't take off, or if it did, it was only due to propwash over the wings.
Thank you TerryMSU for your response as you actually attempted to address some of the issues. Now I'll address some of the points you bring up. The alternator on this vehicle is belt-driven and therefore always turns if the engine is running, and of course it spins faster with the higher RPM's of the engine when I'm driving down the interstate. I multimetered it out at 800 and 2000rpm's and it's giving me 15.3 amps at 800rpm's and 18 amps at 2000rpm's which is what the bulk of my commute amounts to as I spend about an hour on the interstate doing 70. Which is my response to QC's assumption that I will drive differently... it's pretty hard to drive differently if you're doing 70 on the interstate either way... and that's how I'm going to test it, is by doing 70 on the interstate for about 1 hour with each method (without, then with), and refilling the tank at the same pump between each to calculate exact MPG's. Back to answering Terry's concern over the alternator, although I can not be 100% certain, I am about 90% certain that there's no way the jeep is using all 18 amps. I could be wrong on that, and if I am, then it will surely either not work at all, or not work well enough to say it worked at all.
As far as Terry's 2nd concern, I do expect the electrodes to wear out fairly quickly as I am just using copper for this experiment. But it's only an experiment, I'm not making it to last. A few of the so called "professionally made" devices use platnum, while others use stainless steel... but none of those would make much sense to purchase, as they all cost more than what I think could possibly be recovered from the small gain in fuel economy.
As far as automakers having to do anything to meet CAFE standards, they already meet the CAFE standards for the next 15 years with every car and light truck that's already at the dealerships. The CAFE standards are a joke. They are only asking for 1mpg increase over the next 15 years from their minimum standards today (which all those vehicles in the dealerships already beat today's standards by more than 1mpg). They might whine and complain and say we need you to gimme more taxpayer money to keep us afloat because this is just too harsh... but it's not. I do however, wonder why honda, etc, haven't done this... either it's because it doesn't work, or it could be that it damages the engine or exhaust systems somehow, which why I asked the question to begin with.
Thank you to the few of you who have actually addressed reality, to the rest of you, please either start paying attention, start using your brains, or just hit your head on the desk in front of you instead of posting ridiculous things.
SgtMaj
QC
Dude, please understand, your alternator's load on the engine (belts) varies with whatever electrical "load" you place on it. When your blinkers are running your alternator drags more power out of your engine than when they are off, same with the AC fans, cigarette lighter, tail lights and of course your Hydrogen Reformer (that's what it's called). They all create a "load" that your alternator must address. EVERYTHING electrical uses some of your precious gasoline to run it. Incrementally . . . I guarantee this . . .
There are very few ridiculous things posted here. Please, we are your friends. This happens to be what I do for a living . . . For the last 10 years I have sold a device that adds Natural Gas to diesel engines. I am dead serious, I absolutely promise with my iboats' salute of honor, that we are helping . . and some of us (in this thread most of us) know what we are talking about. BTW, I want to know your results too, and I think this is very interesting, but there is no free lunch. There is no free electricity from your alternator, if so, why not run it with your battery to recharge your battery?
Windykid
SgtMaj
Ok here we go. As QC has tried to explain to you to no avail, and you are not listening to the answers to your question.
Let me break it down for you. Hook up your multimeter and check draw at idle, now turn on all lights, fans, wipers, radio, and accessories. now check the reading. Also note if the engine increased in RPM or decreased. Depending on the set up your engine will work harder and normily increase fuel consumption in order to keep it from stalling due to alternator load.
SgtMaj
I'm not so sure it'll work, but I do like experimenting to find out...
By the way, for eveyone that's worried about whether or not the vehicle will survive, let me just say, I could pretty much care less. This is an old jeep whose previous owners didn't take good care of it, and that won't make it another year anyway. It's worth about the same now as it would be if I had to have it towed to the dealership to trade it.
Also, there are no emissions standards in my state, so even if the tailpipe emissions are super toxic, I'm still totally legal.
SgtMaj
Isn't that what alternator's do... recharge the battery?? :confused:
PS - I'm just waiting on some glue to set up before I do a test connection... here's a pic of what I've got so far...
Although it's difficult to tell, the anode and cathode wrap around each other in a double-helix style without touching one another at any point, and are under enough force from the spring-action, that they can't touch even when shaken. That's important because if they did touch, it would be game over... as it would not only cease to function, but would basically be like shorting out the battery, to the vehicle. The only reason the wires look so jumbled is because it's not a solid jar, but rather a plastic 1.5 qt hellman's mayonayse jar with some ridges that distort the view. I needed something with a plastic lid and this was all I could come up with on such short notice.
I know both the anode and cathode wires are red... I couldn't find the same guage solid core wire in black, so I'll make due. It's just an experiment after all.
By the way QC, my earlier comments weren't so much directed at you as it was some of the other comments made such as "this'll be the last tank of gas you'll buy in 2008."
SgtMaj
QC
Reread my quote . . . Yes your alternator charges the battery, but there is a loss between the energy that your alternator needs to replace the amount your battery needs to be recharged. Basically you cannot have an electric motor run an alternator to recharge your battery for the loss of energy to run the alternator? See. If the alternator just sits there and spins with the same resistance with all electrical loads, then why not run your house off of your car's alternator while it idles in your garage? Everything adds load, the alternator reacts to that load and increases it's resulting load on the engine driving it harder to address that increased electrical load. Buuuuuuut, it takes about 1 horsepower derived from your gasoline to create .9 horsepower of electricity . . . or something like that, but you don't get ANY electricity for free . . . None.
jay_merrill
My answer was completely assinine because, well, sometimes my sense of humor demands to be let free.
So, on to the serious answer. There is certainly nothing wrong with fooling with an old vehicle a bit. I do think folks here are right about alternator loads, etc., though.
Let us know how you make out.
MikDee
Banned
Hey Man, More power to ya! Don't know if it'll work, but I admire your moxie, & effort! Just be careful with all that stuff, it could be a reciepe for disaster with all those highly flammable, & combustion supportive, elements. Plus an unstable spark that may ignite it all. Tread carefully on this one, but Good Luck
SgtMaj
Right, but that's what the gasoline is for...
Right, no free electricity.. but since I'm already expending the 1 gasoline hp to get the .9 electric hp ANYWAY... if I can turn that .9 electric into .1 hydrogen hp, then that's an extra .1 hp burning in the engine that wouldn't have otherwise...
I'm thinking about it like this... imagine that the alternator was disconnected from the electrical system for a moment here... the engine and electrical system are running off the battery alone in this hypothetic situation, but the alternator is still physically installed. Even though there is nothing drawing current from the alternator it still spins because it's physically connected by a belt, which costs engine hp for it to be connected, right? And even though there's nothing using the current, the alternator is still generating electric power, but that power is completely wasted because there is nothing using it right? So if you then use that electricity to power an electric motor that somehow aided in propelling the vehicle forward, any hp that the electric motor added, would be an increase in efficiency, right? Ok, so that's basically what I'm thinking will go on here, except instead of an electric motor, I'm going to be using a chemical reaction to create some minute extra bit of hp.
SgtMaj
Hey if it doesn't work, I still had fun... if I blow up the jeep in the process, I had even more fun! :D
PS, I'm going to put off the road test until Sunday... it's too rainy, cold, and miserable out there to go galavanting around unnecessarily.
SgtMaj
