Cruise Craft Restoration
tengals123
Well the time has come. This weekend I will start stripping the boat of all fittings and hardware. I'm really looking forward to this. I have my cash ready, i am going to take it slow and make sure I do things right. This is a full restoration od boat, motor and trailer. I will take full pictures each step with description. Any comments along the way would be great. I will post a link to my project shortly.
tengals123
Re: Cruise Craft Restoration
Is this epoxy resin ok to use for my stringers and flooring, with fiberglass mat??<br /><br /><br /> Norglass Epoxy Sheathing Resin Strengthens & waterproofs timber hulls & decks. Normally used with Dynel Cloth. 2 to 1 mix, supplied with hardener. Size is when mixed. <br />823A 3/4 Litre $38.50 823DX 6 Litres $142.50 <br />823B 1.5 Litre $59.90 823EX 30 Litres $577.50 <br />823C 3 Litres $84.50 <br /> <br /> <br /><br /><br />cheers
Realgun
No :D <br />That stuffs alwfully expensive I though a litre was about a US Quart or so. So the Epoxy would be a 100 a gallon. Can't you have some shipped to you?<br /><br /> I see this is where your buying it eh?<br /><br />Acording to the website it looks like you can use this stuff.
tengals123
i know it pricey, but i want the best stuff. I dont want to use poly resin. what do you think?<br />cheers
Realgun
2:1 epoxy is fine I used System3 and some from US Composites 3:1 I liked the system 3 the best. I got the thick from US Composites and it works well for coating. Can do a Panel in 1 coat rather than 2 and it looks smoother. It might not be soaking in as much but it is flexable and should be fine.
tengals123
cheers, thanks for the reply. Well, im off to work on the boat now. Starting to strip it. I'll post pictures in a few hours. thanks again realgun.
tengals123
Ok, day 1 is over. Check out my progress here------http://www.shareaproject.com/pages/projectTut,p,49,00.html
tengals123
thanks One more cast. Looking forward to tommorrow already
tengals123
ok, day 2 is finished. check my sig. for update pictures. cheers
tengals123
BTW, can i cut the top deck, from the dash thru to the front of my existing hatch. I will be getting a walkthru window, so want to cut a walkthru to my anchor. In the walkthru it will have walls going down to the floor for strength. Should be ok???
Mark42
Tengals123,<br /><br />Project is looking good. The boat looks like it is a good solid design. I would not cut the dash, though. That deck hatch is rather unique to your boat, even if it's not all that practical from a use standpoint. And I don't think a walkthrough windshield would look "funny" on the boat with a solid dash. Just being able to open the windshield is a nice feature. Maybe add some additional bracing to the dash and you can crawl throught the windshield out onto the deck to retrieve anchors, etc.<br /><br />Got any plans for instrumentation? Guages are cool, and you can't have too many!<br /><br />One more thing. I see you are cutting down the seat posts. Not a bad idea from a performance standpoint. There are lots of nice upholstered bucket style seats available. If you pic a seat style from a specific manufacturer, then you may be able to get the matching vinyl by the yard from them to cover the new rear seat you are planning. Just a thought.<br /><br />Keep us posted.<br /><br />Ps. Don't throw out any parts you remove, no matter what the condition. You will find that they come in handy when trying to get replacements, or showing to a parts counter person when you have to describe it. Also, the profile of old rubber/vinyl strips are handy for matching up to catalog cross sections.<br /><br />Mark.
tengals123
Mark, thanks for the reply and great advise. Right on with the trimming and seating. I have already done that. Two tone, excellent quality seating. Bucket seats are done and they are going to match the rear. All seamed and rolled. It will look great.
tengals123
also, i'm installing a below deck 65litre gas tank. Where would you suggest i locate the filler and air vent. Filler to the same saide as my car filler. The main thing is the vent. Ive been told unless its near the rear facing away from the boat, it will smell of gas all the time. is this true?? any idea's??
Realgun
Make sure the filler is as High on the side and rear as you can get it. <br /><br />The vent should have a 12 inch high loop in it to keep water from getting in and gas from geting out. Location should be above water line :D and on the rear of the boat to aviod fumes. You may also want- this or This.
tengals123
thanks, ive ordered stainless filler and vent.
tengals123
control box question....<br />i want to paint my merccontrol. It's metal what to use. sand, clean, prime and paint. What primer and what paint??
Tinkerer
Originally posted by tengals123:<br /> control box question....<br />i want to paint my merccontrol. It's metal what to use. sand, clean, prime and paint. What primer and what paint??
Is the current finish in generally good condition or is a lot of metal showing?
