cruise speed
Spidybot
Re: cruise speed
Please state your motor and boat - someone around here may have one like it and be able to tell you right away.<br /><br />Normally your best mpg is where your boat is planing. Provided you have the right prop and get on plane, draw back as much as possible on throttle to the point, where you have a clean plan. To be able to do this you may have to redistribute weight in the boat.<br />This way you get the highest possible speed at the lowest possible fuel consumption. It is important that you do not get below clean planing. Imagine the position just before planing, when your bow is at it's highest and think about how much power it takes to perform this lift.
ledgefinder
Ensign
Re: cruise speed
For a sailboat (displacement hull, rather than planing), try a knot or two below hull speed.
Spidybot
Re: cruise speed
Sorry, took it for granted that it was a planing hull.<br /><br />I agree with Ledgefinder but would like to add, that fuel consumption suffers at WOT. I'd keep below 75% of full throttle.<br /><br />Regarding hull speed, it's the hull lenght in the waterline that counts. <br />Easy rule is lenght in metres equals the speed in knots ( 20 feet = 6 metres = 6 knots ).
