Re: cyclinder#1 122psi#2 122psi #3 120psi #4 0 psi
I used a Clymer's Manual it was ok, kind of confusing at times because it covers many models. In hindsite I would get the OMC manual. It will cost just a little more but it will be worth it. My neighbor had the Clymer's so I used it. I read the manual serveral times before I removed the first screw. I took lots of pictures and labelled every nut and bolt and I put them in baggies with notes where they came from. It was a fun adventure, a little nerve racking at times when you are in foreign territory. But it saved me mucho $$, I learned alot and I know it was done right.
Depending upon how complete of a rebuild you want to have when you finish there are many other things you may want to consider replacing when you have it all apart.
