roger3645
- Joined
- Aug 30, 2005
- 271
I recently went and looked at a Ski boat which was powered by a 1989 Johnson 140hp looper. I was actually only interested in the boat for the motor. If, I had bought the boat, I had a guy I was going to give the boat and trailer too, after I pulled the motor. I found the boat had a bad floor and transom. The boat has been sitting in a self storage lot for over two years. Using a fully charged battery which I brought with me, I did a compression check. The motor wasn?t really turning over that fast and I got these numbers, 100, 90, 100, 100 (too low for me). I sprayed some WD40 into each cylinder and got the same numbers. But the motor did turn over a bit faster. Since the boat was in bad shape (I don?t have room to store the boat) I let the boat go. I just have this haunting feeling, that the motor most likely does have better compression. I am thinking since it has sat so long, the engine probably wasn?t lubed, causing it to not turn over fast enough to get a good compression reading. I did pump the primer bulb before the compression check. The boat is still for sale.
Question is: Did I give the motor a fair evaluation?
What do you think?
Thanks
What do you think?
Thanks
