Yesterday I ran the boat for about 25 miles and had no problems. I filled the tank up when I got in (~20 gallons) and then I realized that I was out of 2-cycle oil. The only thing open was walmart and they were wiped clean of 2-cycle oil except for Penzoil Marine Synthetic Blend TCW3 that claimed it was compatible with premix engines. So I added the synthetic oil in a 50:1 ratio to the 20gallons of gas that I had just put in (there was probably a few gallons of gas with regular oil in it remaining). Today I ran the boat and after 20 minutes I noticed that the engine was loosing power and the boat was having trouble planning. I switched over to my portable tank which had regular TCW3 oil but the problem persisted (damage already done?). I got back to the dock, cleaned the spark plugs, and tried again but had the same results. Does anyone have any experience with using a synthetic blend in a Force engine and could this be my problem?
The only other thing that I noticed was there appeared be a green residue (oil/fuel residue?) that that looked like it came out of a hole at the top of each carb (I think its the vent). I had just rebuilt the carbs back in June. I also have both a fuel/water separator and inline filter installed on the fuel lines. Any advice would be appreciated.
