FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
1987 85HP. I have a broken carb. My friend gave me as set. but they are missing the jet on the center post inside. will they still work. See pic my old one is on the left.
Broken how? A carb will most likely not run correctly if it is missing a jet. They regulate the gas flow to a carb, and without it, it probably won't work...or at least correctly. Why don't you order a replacement jet for the carbs?
Thom if you look at the pic the one on the left has a jet on the post, the one on the right does not have a place for the jet.The housing at the mounting hole broke.
it could be the jet is located at the bottom of the center post while the old one has its jet on the side. There's no such thing as a carb having no fuel jets, I mean as far as this old carbs are concerned.
I am using the whole set. The Throat is the same size. I believe the jets are the same size, and the little tubes in the stem are the same. I'm going to try them today.
