evilgenius877
Thread starter- Joined
- Jun 4, 2008
- 27
i have a 2001 35 hp johnson. at first i wasnt sure if i had any spark in fact im almost 100% sure that i did not have any and that was why it would not start. so we went down to check again and we did have spark afterall. so we re-checked using a spark check and also took each plug out 1 by 1 to check gap and such.....when i got to the second plug i took the wire off of the plug and went about hooking up the spark tester. we turned it over and it fired right up. so we hooked it back up and it ran rough but it did run. after checking the third plug it wouldnt run anymore. it would start for a split second but die almost instantly. i also noticed that the ball pump was extremely hard i mean solid! we clearde it out and still no start. we didnt run it enough for it to get too hot to not run (we had that problem last summer it was a power-pack and it was replaced) i bought a shop book and a multi meter today but i have noo idea where to begin. the spark is pretty good looking so i dont think that is it anymore unless i touched something and this was all a fluke. TASHASDADDY told me to check the power-pack, stator, regulator/rectofier, being that we put a new power-pack in last summer that will be the last thing i check tommorow. where else should i be looking. dose this sound like a fuel problem? kinda right? not sure but i desperately need help! thanks in advance
Johnny "evilgenius"
Johnny "evilgenius"
