Re: DIY-1972 thunderbird shawnee tri-hull boat restoration-(after shop repair gone wr
[SIZE=-2]
[SIZE=-2]Resin requirements for 1.5 oz mat.[/SIZE]
[SIZE=-2]38" - Needs approx. 24oz resin per yard (from US Composites site)
So, 3' X 6' is 2 sqare yards 20 48oz of resin per layer of CSM.
2 layers per side 96oz of resin per side
2 sides 192 oz of resin
this is just for the CSM layers, you will need 1708 there for structure as well
[/SIZE]
[/SIZE]
lol....the calculations for resin usage are totally dependent on several factors....
for a supplier to give a baseline formula like that is ok.....but in real life it does not work that way.
temps......degree of surface prep... different drynesses of a substraight .....change all these factors.
not to mention that a novice (or even a pro) will coat glass with the same resin to glass ratio every time....
when you glass......it is common to use too much resin to wet out the glass.....the excess resin is removed with the resin roller....and removed from the project.....it is now useless. thus....your calculations are right out the window. it is also common to have resin left over in a bucket after a job. this is waste.
using a slide rule and calculator to determine what you need for the materials.....just gives you a headache, and is allways wrong.
order what i estimated. and you will be good.
if you cannot afford it all in one sha-bang...........get your plywood now......wait till next pay check.....order half the materials on the list. (order for what you will be doing the next two weeks......then order the final batch....this will break down the order so its not all paid for in one shot. and much easier on the pocket book
