bigdee
- Joined
- Jul 27, 2006
- 2,667
Re: DIY drill hubs and add zerks - advice sought
A++++ Bearing Buddies are a must on any trailer that gets dunked in the water......the theory that smokonthewater stated works, it is just as simple as that.
THIS! hard to argue with success.... or you could drill n stuff.... Keep in mind tho.... no ez lube or homebrew version of same will stop water intrusion like the BB's will.... drive down the road and bearings get warm creating positive pressure and seeking to leak air past seal and hub cap.... dunk em in cold water and a vacuum is created which wants to pull water in... The bearing buddy keeps positive pressure at all times so water is never pulled in
