I have a 1984 140 HP mercruiser its in a 16' sting ray if that matters . Any way the boat use to run great then it quit cranking . It was obvious the electrical parts needed replacing so I replaced everything except the coil and the distributor . I made note of how everything was set before I took it all apart because I didn't know if I would be able to find the specs for a motor that old . So I did find the specs and set the points to .022 and the timing to 6 degrees BTDC . Now the boat runs like crap . Its hard to get it up to speed and it spits and sputters doesn't have near the power it did before and theres no way it would pull a skier up .
So i set the points to what they were before . .025 and the timing to what it was before 13 degrees BTDC . Now the boat runs almost as good as before but not quite . I think the timing before was set more like 16 degrees BTDC but when it gets that far over its just a guess because the pointer on the motor doesn't go that high .
The guy I bought the boat from said that the engine had been rebuilt . while he lied about a multitude of other things I think he was telling the truth about that because of how good it has always ran and the fact that it doesn't burn any oil . So i'm wondering whats the deal . I was expecting the boat to run better than ever after the tune up .Does a rebuild negate the original points and timing settings ? If not then could someone enlighten me as to whats going on with this .
Thanks in advance
Thanks in advance
