phil rogers
Thread starter- Joined
- Apr 22, 2008
- 31
I have 77 140 r or 1 lower unit.I pressure tested it seems to be leaking between the water pump and the lower case.Is the upper shaft supposed to have side to side movement.I thought if that is not normal that maybe where the leak is.I put a new water pump on it last year was filled it with oil and it had water in the lower unit with a brief run at the lake.I put new prop seal and shift shaft seal but it still leaks water in the lower unit. help please thanks phil
