does this make sense? drilling out something in the carb?
pvanv
Re: does this make sense? drilling out something in the carb?
I like the pretty blue grease :)
Looks fine...
dtj
If the inside of the carb is as clean as the outside then you are good to go..........Don in Redondo
ngt
thanks guys. took it out today and it ran like a champ! I brought it home, flushed it out with fresh water, then unplugged the gas line and ran it until it died. I also put sta-bil in the gas today. How long do you flush your motors when you go in salt water?
pvanv
Depends if you are using the flushing plug or muffs. The direct connection to the plug can dump a lot more water, assuming you have a lot of water coming through the hose, and if you have the inlet strainer taped off with duct tape, and so can flush a little faster. Probably 5 or 10 minutes on muffs is plenty. That's long enough to idle the carb dry, BTW.
ngt
I just stick it in a garbage can full of fresh water with a hose stuck in there letting the water overflow and the motor **** off the the side. Is this ok?
pvanv
Yep.
ngt
cool. Still 5-10 minutes like this ok?
