sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
This is a 1996 Evinrude 48hp, Esledc, it is a motor of a friend of mine. Dealer said powerpack was bad and changed it. Problem was still there. He brought the motor to me and I found that it was dropping spark completely and then picking it back up again, about mid rpms. Checked brown wires from power coil, and the DVA dropped from 280V down to 0 just before the "miss." We pulled the flywheel and changed the charge coil and timer base. I also changed the dual ignition coil just for kicks.
Anyways, I had checked the blocking diode in the engine harness, and got 636 ohms one way and infinite reading the other. I assumed that was good to go.
Problem STILL exists. The entire ignition system is brand new. I hooked up the old powerpack, and left the tan wires disconnected and the alarm in the box was buzzing. I think the pack shorted and took out the blocking diode when it initially failed. Put the new powerpack back on and alarm triggered on and off and then stayed off.
Does this sounds like a blocking diode to you guys, even though it seemed to have tested ok? Is there anything electrical in the boat side electrical system that needs to be checked? At this point I want to change the diode because it is highly suspect........
Here is a vid of her.
