dp-c1 question
duckman4548
I have a dp-c1 outdrive on a Formula 233, while running on hose I notice water is coming out of the 2 "pipes" against the hull from the drive, is there any water that exits the cavitation plate on the rear of the drive where rubber flap is or just exhaust Thanx
K-2
Water does come out with the exhaust.
I don't understand what you mean by "2 pipes against the hull"
duckman4548
Sorry, against the transom on the transom ass. plate is 2 tubes that water is flowing out of when running and exhaust out the cavitation plate with the rubber flapper with very little water, my question is , is this correct or could he raw water impellor be getting ready to go. Thanx
captmello
What you are seeing is normal. Those tube are called idle relief ports. I think you'd find that once you have the drive in the water, and the raw water pump is pumping at higher rpm's water will come out the exhaust as well. But you can't see it, just take my word for it. If the impeller is 2 years old, change it.
