- Joined
- Jul 23, 2011
- 53,045
the story - found the only @#$#$@ rock in 5' of water in a sand bay - could have also been a sunken boat as it wasnt on any chart, or marked
the good - minor chips in the props, easily repaired
the bad - spun a hub on the rear B6 prop which then ate up the plastic washer.
anyone have a good list of the component part numbers?
I found this list by name, however would like part numbers so I can find and order them. any and all help appreciated in advance
The proper order then of the parts front to rear is:
1. Rear fish line protector (must fit inside anode)
2. Rear prop
3. Plastic washer
4. Tab washer
5. Spanner nut
6. Thrust washer (may/should be "stuck" inside the rear fish line protector)
7. Rear fish line protector
8. Rear prop
9. Plastic washer
10. Cone nut
2. Rear prop
3. Plastic washer
4. Tab washer
5. Spanner nut
8. Rear prop
9. Plastic washer
10. Cone nut
