Re: Driving with trim in up postion
Ok so had a little free time today to do some trouble shooting. I located the 2 barrel connections behind the engine. I used a multimeter and put one in each barrel. When clicking the trim OUT/UP (not trailer) button on my throttle the meter reads 12v. So sounds like the switch is sending a signal to the limit sensor, but the sensor is faulty?
Sorry for sounding like a total newb, but I don't work on things much often. Does my diagnosis sound correct?
If you pulled the connection apart, or the drive was not Fully DOWN, it means little/nothing.
With the Drive Fully DOWN. Unplug the Sensor wires.
Measure the Resistance/Ohms of the two wire going to the Drive.
They should show a short. An Open circuit is a bad Limit Switch/Sensor.
Now Short Together, the two wires from the wiring harness. Simulating a Limit switch in the DOWN Position.
The normal Up/Out button should now work. It will not stop, but it should go UP.
If it works with the short, the Limit Switch/Sensor is bad.
If it doesn't work the problem is Not The Limit Switch/Sensor, and is elsewhere.
