kevinclark93
Thread starter- Joined
- May 11, 2009
- 42
I have a 1985 DT85. I recently bought a service manual was going through it checking everything. There appears to be an issue with my timing linkage. My advancing lever does not engage the adjuster plate in the full advanced or full retarted position. If i manual move the advancing lever it will engage both positions depending on if i am in gear or not. Once it is manually move it will stay in that position. Also when it is manually moved to engage the adjuster plate the timing alignment marks line up according to spec in both positions, so the adjuster plate is in the correct spot.
I have attached some pics of the lever fully retarted and fully advanced, also one pic of the assembly. Could this just be a weak or dirty spring (#15 in the last pic), or is there something i am missing.
