jgrisham02633
Thread starter- Joined
- Jan 26, 2005
- 126
Just picked up this boat and never worked on a suzuki before, Boat sat for fourteen years, I hooked up the gas and fired her up, pop and run for 2 secoonds, die, tons of fuel running out of a little hole at the top of the carb when I pump the bulb, so much that the motor went up in flames and lit the ground on fire, it was quite a show!, anyway i was quick with the extinguisher and no harm done, but before I give it another try I figure I should ask you guys about the fuel leaking out , and give you a laugh. Help would be appreciated, thanks Pics below
http://www.avak-tech-online.com/carb pic.jpg
