Dual Battery Setup
Don S
Re: Dual Battery Setup
If there is an award for over engineering an electrical system on a small single engine outboard boat, you win hands down.
Auger01
Thanks, I think. I can do simple, but that wasnt the objective here.
Silvertip
Did something scare you?
Nope. But have you ever heard the expression --- this is like driving a tack with a post mall? Your boat, your money so nothing we can add if it works as planned.
NYBo
Complexity aside, that's amazing. I love the IP, too. Two questions:
1. Are those toggle switches water-resistant?
2. Where is the flux capacitor?
Auger01
1. They have rubber seals inside, and they make rubber boots that will cover them copletely. If water intrusion in the switches becomes a problem or I decide to hit them with a pressure washer, I will install the boots.
2. The boat wont go 88mph so the USCG doesnt requie one. :lol:
Don S
I do have one question, why the wire between the engine and house fuse panels?
bruceb58
Is that panel silk screened? You make it or have it made?
Auger01
Auger01 said:
If you look in the picture above, you can see a 10 gauge wire connecting the fuse blocks. That normally wont be used, but if there is a problem, I can open one of the 50 amp breakers above the fuse blocks and plug in a fuse on the 10 gauge purple wire to combine the fuse blocks.
I am using it currently now to power up the engine bus because I dont have the engine harness or engine installed.
Auger01
I had it made. It is .090 plus or minus stainless plate laser marked. I would have preferred actual engraving but I couldnt find a place that wanted to do it.
Auger01
So take one, install it per the directions, it does all he wants, and sell the rest off and get some cash back. :D
One will do all I want? Could you sketch that up for me Bubba since you seem to know what I want?
By the way, I always try and read the thread before I make a post. It usually keeps me from looking like an idiot.
bruceb58
Oh, as to looking like an idiot... That usually falls on the guy that shows up here, has never wired a boat, and doesn't want to listen to what experianced people are telling them. Even then, we don't call them idiots. Maybe have their posts deleted for abuse of the forum, but not call them names... (Hint: Tread lightly in the future...)
I believe he was talking about keeping himself looking like an idiot.
Don S
"The main goal of this design was to allow for a day at anchor on the lake listening to the stereo and yet not have to worry about having enough juice to start the motor. I also designed a bit of redundnacy for safety. The system is flexibile, you can start on either battery and keep the batteries seperate or parallel them together. It is also made easy enough to use to that my wife can easily operate it."
Well lets see, if the above is what you want and I assume it is then the single unit will take care of it. Take a look at the specs. http://assets.bluesea.com/files/resources/instructions/990180170.pdf (The only thing I see it won't do is let you try to start the engine from a dead house battery on it's own.)
I may be missing something here, but here is a picture of what he has and wants, how can you possibly do that with only one switch.
attachment.php
bruceb58
Maybe I am in the minority but I like the setup.
Obviously money is not a problem based on the Garmin gauges!
Bubba, as far as being standard fare, I can't believe you can make that comment based on the Rube Goldberg design you are attempting to do a series parallel battery hookup.
Don S
Don I am going by what he said he wanted in the original post. Combine/ isolate the two batteries, run devices off the house battery without draining the starting battery, recharge both batteries when the engine is running, simple to operate remotely. Sounds like pretty standard fare to me. Maybe I am missing something...
How do you use one single on/off switch to operate two different systems?
That is all that Bluesea switch is, a SPST switch.
It can be turned off and on electrically or manually, but it's still a single pole single throw switch with a large amperage capacity.
Don S
Again I guess I am missing something based on what he said his objectives were.
Why don't you just do as the OP ask and make up a quick drawing showing how to use just one of those switches?
You have already listed what he wanted.
Just not sure how you can do the underlined part above with a single switch.
