This may seem stupid, but does the key switch on a Mercury have a built in alarm or not? When I turn the key from off to on position, I am not getting a "beep-beep". I know I used to. Everything seems to be working ok, the alarm (which is seperate from the key switch or instruments) sounds if I ground the tan wire in the engine simulating high temp, so it is working. I can't seem to find any info about the switch, or any truth tables on what contacts should be doing in the 3 different positions ( open or closed between which terminals).
Any help would be greatly appreciated!!
Thanks, Dave
Thanks, Dave
