Duo prop?
smithrock
What are the advantages of running a duo prop over a single in a 23' boat?
Re: Duo prop?
Ayuh,... Why are you asking the Same Questions in Multiple forums,..??
Cross posting is frowned upon,+ causes Much confusion....
Btw,... Instead of asking all these questions,... Use the Search button,...
All of this stuff has been answered multiple times....
smithrock
Re: Duo prop?
Didn't mean to!!!! I had that question included with my other post. I deleted that part of it and thought better to put in in the correct forum!
Do you have an answer?
sbbamafan
Re: Duo prop?
More efficient:)
Better control in reverse:)
Better tracking forward:)
No torque steer at given speeds:)
Usually lower top speed:(
Higher initial cost:(
Expensive prop sets
TilliamWe
Banned
Re: Duo prop?
More efficient:)
Expensive prop sets
Additional plusses:
Faster to plane
Able to hold a lower speed and still be on plane
Less "blowout" in tight turns while on plane
More "bite" at idle speeds in both forward and reverse
Additional minuses:
Faster speed in gear at idle (you'll hit stuff going faster than you'd like)
Increased risk of corrosion to the outdrive (Bravo 3 especially but also VPs with stainless steel props)
The slower top speed is not much, btw. 1-3 mph, tops, depending on horsepower.
The advantages of a counter rotating prop system far outweigh the disadvantages.
