Durbans epoxy paint formula ,paint on almost anything 100% water proof & petrol proof
durban
Re: Durbans epoxy paint formula ,paint on almost anything 100% water proof & petrol p
more photos , just some that was poured out after i epoxy coated the inside of the block into oily a tray , and left it , the next day it had gone hard , & the pieces that has been in the container for 3mths with petrol from my motor that i used to was parts with , i will upload the formula on top secret file tonight , cheers
now ive given you a good tip , can some one take me fishing , please , i don't have a boat ,i am gonna find one & fix it .cheers
I left this piece in universal thinners for a week . & did not change in any way still got the gloss on .today i put the same piece in the oven under grill for 45 min & nothing changed
phillnjack2
Ensign
"now ive given you a good tip , can some one take me fishing , please , i don't have a boat ,i am gonna find one & fix it .cheers"
ill take you fishing Durban, no worry's at all mate.
only 1 problem, i live in the uk :eek: ENGLAND
phill...:)
durban
today i did something with my formula where i made up a under coat to go with it , & end results are even better , the advantage now is that you only need one finishing coat .
NOW IAM READY TO GO WORLD WIDE , this product will take the marine industry by storm , we can get an international patent for this product . i hold all the secrets to this formula . apply with in if you interested ,the new under coat i got is definitely the answer i was looking for it puts even a better finish to the job , ive just finished doing this transom bracket & took a photo in the dark with my mobile ph . its not a flash phone but happy it works ok will take some tmrw during the day & upload
durban
busy with this 1974 70hp this is my rad con motor the exhaust adapter had a big hole from salt corrosion exhaust fumes escaping ready for the bin the aluminum couldn't be welded corrosion made it very thin in some areas . I fixed it using my epoxy formula & epoxy coated the whole adapter
durban
the whole motor has been done inside & out with tremendous help & results from my Nitric acid formula
http://forums.iboats.com/showthread.php?t=527764
