Durbans epoxy paint formula ,paint on almost anything 100% water proof & petrol proof
durban
when i did my 60hp points conversion , i was looking for a good paint , found TOPLAC ,at 96dlrs , bought the best brushes , but was unhappy with the finishing touch , could see faint brush lines ,So started some research , but could not find a marine paint to do my hobbies & the colors i wanted , as toplac only have a few colors in the book i got from the fiber glass shop & give me a professional finish . i stared experimenting & formulated my own epoxy paint , which is available in all colors in the rainbow & u can also mix & match to suit the color u want to mix , It sticks on almost anything i could find to paint , wood , plastic , rubber , building bricks , aluminum , steel , polyester resin , & doesn't leave paint brush lines , i have even epoxy coated all the water ways in my motor & did some modifications inside the block with it ,drilling & taping threads into it [ the epoxy mix ] , i painted a piece of aluminum & put it in the oven at 89 degrees heat , & it showed no signs of coming off the steel , it gave me the go ahead , to use inside my motor . It cost me 50dlrs to buy ,as appose to 96dlrs , never mind you still have to buy the undercoat that comes with it ,so the price goes up ,k My mix , no under coat , when i finished there was some left in the tin that had gone hard , so i took it out & left it in PETROL , 3 months , it showed no signs of side effects wot so ever , u can spray it on with a spray gun , by mixing it with lacquer thinner to . I called the fiberglass shop owner over to my house & showed him the difference from his product & my mix , THE MAN COULD NOT BELIEVE WHAT HE SAW , THE GLASS FINISH IS GLASSY , DONE BY HAND WITH A PAINT BRUSH . have a look at the leg of the motor , done with toplac , & the gearbox done with my mix , u will see the difference , cheers if you want my formula ask & i will give it to u ,k
StillFishin'
Re: Durbans epoxy paint formula ,paint on almost anything 100% water proof & petrol p
I'd be interested in it. Send to EDIT:email address removed, send PM
kfa4303
Banned
Hi Druban. Between you're Halloween themed motor, machine work on the heads and bullet proof paint formulas, you're becoming our resident evil genius :) Kiwi Power!
durban
no harm , in sharing knowledge , my pleasure , thanks
62 ROYAL SCOTT
HELLO durban can you post or send me the info.on ratio mix and what to buy i would like to paint my 62 boat trailer.that looks real nice :) THANK'S
Cap'n Chaos
I'm interested in your paint formula as well.
geoffwga1
Me too Durban,why don't you post it to the top secret file.
Geoffwga1
durban
Geoffwga1
k , i will do it later tonight , just working on my motor at the moment, k
durban
more photos , just some that was poured out after i epoxy coated the inside of the block into oily a tray , and left it , the next day it had gone hard , & the pieces that has been in the container for 3mths with petrol from my motor that i used to was parts with , i will upload the formula on top secret file tonight , cheers
now ive given you a good tip , can some one take me fishing , please , i don't have a boat ,i am gonna find one & fix it .cheers
durban
how do i get to post on top secret file , need help never done it before
durban
epoxy resin name : West System 105
hardener : West System z 206
Paint: Deltron , its an automotive paint , that mixes very well with the epoxy resin & comes in all colors of the rainbow
formula:
6ml epoxy resin
1.5 ml hardener
2ml Deltron paint
mix the paint with the epoxy resin first , when you ready to paint then mix in the hardener , you have 30 - 40 minutes working time , so i mix small amounts at a time just enough to do the job , otherwise it goes hard & you end up wasting .
to spray on mix with lacquer thinners
x 2 to give you more volume for larger jobs , drys after about 6 hrs , 12 hrs very good & hard apply 2/3 coates
62 ROYAL SCOTT
THANK'S durban,for the info.my boat won't be ready until late spring,it's a 1962 ROYAL SCOTT DELUXE 15 SWIM & SKI WITH A 43.7 ROYAL SCOTT CUSTOM O/B SITTING ON A SCOTT TILT TRAILER . I HOPE YOU GET TO GO FISHING SOON ----THANK'S AGIAN
durban
a person with your rank you have , should rather put ,something on this site useful on this site for the boating community to use , instead of your sarcastic remarks , have a good day
kfa4303
Banned
No sarcasm intended Durban. I have admired your work thus far, as have others. I would suggest a bit of proof reading on your behalf, however. It's a bit difficult to tell what it is your trying to say exactly.
durban
no worry m8t , my Halloween motor is in my garage , it happens to be the only one in the world , & my epoxy coated block is probably the only one in the world too & we here in NZ are proud to be one up on you fellas , NZ does have some evil geniuses , send your FBI over & i will show them all the proof they need to see , k , have a lovely day m8t
kfa4303
Banned
A wee bit testy aren't we? Simmer down Durban. There is no competition between you and I, or either of our great nations. I'm sorry you feel that way. I would reiterate my concern for your lack of punctuation and grammar, however, but I fear it may be fall on deaf ears. Fair winds and following seas.
durban
i don't have any issue with that , nice to get to know you , you see my epoxy coated block gonna take the world by storm , the people that build outboards may even follow , and the epoxy paint too , what do i get out of it all , for sharing this with the world , i don't even have a job , i should have kept quiet & started my own little job , but i be leave in sharing with the universe , in some way or other the powers in the universe , give back , k
kfa4303
Banned
So much angst and anger. What a shame. Boating is generally considered to be a relaxing hobby by most, but not all apparently. By the way, there are other punctuation marks aside form the comma. You may find that their proper usage not only makes your own comments easier to follow, but will serve to better your chances of future employment. Just a suggestion. It's certainly not as earth shattering as "epoxy paint" (truly a revelation, aside from the fact that you can already buy it at virtually any paint store), but it may be worth considering nonetheless. Happy boating.
durban
you missing the whole point you don't call someone evil ,i am a Christian & that's what pissed me .
nwcove
well, this thread has taken an odd turn! .......durban......i have enjoyed reading your posts too! and here, in north america, being called an evil genius is a term of endearment, being called a genius of any sort shouldnt be cause to get your feathers ruffled!! keep up the posts, and the creativity.
tim
